Thanks for the app, noob question here,
I've installed the extension, just setting up, where can I find the Widevine Device file?
Results 361 to 390 of 716
Thanks, I've installed and it seems to be working, how do I now download the video file from this data?
what websites are you trying ?? try this video from tubi and see if it works there - https://tubitv.com/movies/679223/the-three-stooges-in-orbit
also make sure that you have the extension pined to your toolbar. -
Thanks mate, it's working now, trying shahid. Screentshot in post above, how do I now download the video?
Just want to say thank you and really appreciate the help, I am a bit of a noob with this, running the cmd in terminal and getting an error
[Attachment 85988 - Click to enlarge] -
do you have N_m3u8DL-RE installed ??
see here - https://www.videohelp.com/software/N-m3u8DL-RE
and here - https://github.com/nilaoda/N_m3u8DL-RE on how to install on your computer. -
I'm getting closer.
I have ffmpeg and N_m3u8DL-RE.exe saved in a folder.
I run cmd, it's doing something, then after about a minute I get a windows error notification, this programme cannot run, and also the cmd error access denied.
[Attachment 85996 - Click to enlarge]
[Attachment 85997 - Click to enlarge] -
Windows 11 Home version.
More progress, I downloaded another version of the exe file, this one to be precise
Download N_m3u8DL-RE 0.3.0 Beta Windows 64-bit
Iam now seeing a new menu in cmd. I'll let you know how it foes, thanks mate.
[Attachment 85998 - Click to enlarge]Last edited by Drillakilla; 9th Mar 2025 at 05:10.
If someone could help me with how can I view and select the HEVC stream/s to download? When I run the command, it only shows h264 streams and I know it has HEVC 4 K streams.
Tried to run on pr#me video and the video won't play unless I update chrome, chrome is up to date.
When I deactive the extension the video plays, any thoughts, I managed to play the video but nothing is populating in the keys section?Last edited by Drillakilla; 9th Mar 2025 at 12:35.
this is normal, happen all drm streaming sites. click + to see all
[Attachment 86017 - Click to enlarge] -
I'm not getting anything populated in the + section.
I get a chrome update message when the extension is enabled (chrome is fully up to date)
[Attachment 86018 - Click to enlarge]
When I disable the extension the chrome message disappears, I can now play the video and I can then reenable the extension,
[Attachment 86019 - Click to enlarge]
after reenabling the extension, the keys + area does not populate.Last edited by Drillakilla; 10th Mar 2025 at 09:52.
Interestingly, the extension only seems to work on shahid. I tried tubi as well, the videos play and the keys do not populate.
there is other extension which is can fetch 1080p CVBR keys
[Attachment 86029 - Click to enlarge]
[Attachment 86030 - Click to enlarge] -
Does WidevineProxy2 handle streams from Max with L3 CDMs? Doesn't seem to handle it.
Lol. Nope. Need a computer science degree at this point versus WVP2's install and go.How To Use?
Load config templates for Remote CDM, See example
Go to this repository PlayReadyProxy-API -
I changed the CDM and managed to get it to work, keys are populating. RESULT!!
I downloaded some videos, however, i ran into an issue with some videos, as the tool is getting the video, the video file size keeps growing and never processes beyond 80%, see screenshot below, it never finishes and I end up running out of space and cancelling the tool.
[Attachment 86039 - Click to enlarge]
How can I fix this? -
what about playreadyproxy with prd remote????any news????trying but not working for me......how should i make the api with the apikey i got with the generateapikey.py???if i launch flask in 8080 port, maybe can i put my prd sl3k in it???im trying but with not results
[Release] Widevine L3 Guesser Extension-Works in 2024 Firefox/Chrome All OS
By FoxRefire in forum Video Streaming DownloadingReplies: 795Last Post: 15th Oct 2025, 11:19 -
[Release] WidevineFetch - Keys from just the License URL; Any Lic. Wrapping
By larley in forum Video Streaming DownloadingReplies: 262Last Post: 4th Sep 2025, 04:00 -
MY5:- HMAC and AES: NO BROWSER REQUIRED Stand-alone script.
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 10Last Post: 22nd May 2024, 10:18 -
Lic with jsondata
By sangoku in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2022, 15:02 -
help decrypting drm dash hmac
By filipino in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2021, 06:07
Thank you.
